Activity Forums VEGAS Pro working (slowly) with big files in Vegas 10a
  • working (slowly) with big files in Vegas 10a
    Posted by James Redmond on December 3, 2010 at 6:12 pm
    Since going High Def my system has slowed to a crawl. Sometimes I have to wait several minutes when I jump around on the timeline for the cursor to arrive at that location, ready to play both the audio and video.
    I am using both files from a Tricaster (MPEG-2) and Canon XF305 (MXF). The last MPEG-2 file was 1 hr 15 minutes, approx. 48 gigs.
    I am using Windows XP 32 bit SP3
    Sony Vegas 10a. 32 bit
    RAM 2 Gig
    Intel Core 2 Quad Q9300 Processor (2.5 GHz)
    in Vegas Dynamic Ram preview is set to 350 mgs
    Max Number of Rendering Threads 4
    Is there a setting I can change?
    Would increasing the ram do much?
    in the next few months, I plan on upgrading the computer system…
    Thanks! James
    James Redmond
    Dynamic Videos, Inc.
    Rogers, AR USA
    James Redmond replied 15 years, 9 months ago 3 Members · 3 Replies
  • Mike Kujbida
    December 3, 2010 at 7:25 pm
    James, a core 2 quad is somewhat underpowered for the kind of footage you’re trying to use on it.
    I just took delivery of a Tricaster too and had no issues on the quad core box I have, even with 1080i footage in HQ mode.
    I haven’t tried anything fancy yet but basic single stream playback was just fine.
    Hopefully your new machine will be an i7 with lots of RAM and 64-bit Windows 7.
    Then you’ll be flying around the timeline and wondering why you waited so long to upgrade 🙂
  • Davd Keator
    December 4, 2010 at 4:45 am
    Yea, a quad core must have 8 gigs of ram. Punch up your resource monitor/ You will see that your ram is maxed out and you are hitting the Swap File “Virtual Memory”!
    I using 9e consitantly hit 6.5 to 7.5 gig utilization.
    Your processor is okay for HD, just about 20% slower than an I7 92o during render times.
    Up grade to Win7 x64 pro.
    throw in 6 more gigs…
    You’ll be flying smooth…
    Wait for sandy bridge or Interlogos from AMD.
  • James Redmond
    December 4, 2010 at 3:22 pm
    Mike and David, Thanks for your advice.
    Maybe an interim step would be to upgrade to Win 7 Pro and increase the ram to 8 gig, as David recommended.
    Would you recommend installing Win 7 Pro OEM, instead of the upgrade Win 7 Pro? Seems like it is always better to start with a fresh install. And the OEM version is less expensive…
    Thanks, James
    James Redmond
    Rogers, AR USA
