Activity › Forums › Apple Final Cut Pro Legacy › Working out of WMV exports
  • Working out of WMV exports
    Posted by Ignatius Gorin on December 4, 2010 at 11:51 am
    Hello —
    I’ve been asked to do a medley cut out of several small films I did, point is: the only source clips I’m left with for those are WMV 1280x720p exports.
    My question is what would be the best way to reimport these into a timeline, cut, add some titles, a little graphic design and export to 1280x720p so I don’t lose too much quality ?
    E.g. any particular sequence format to use, “tricks” or dos and donts?
    TIA.
    Ignatius Gorin replied 15 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    December 4, 2010 at 2:23 pm
    WMV’s can be edited with FCP, however they don’t work with RT extreme (the real time playback of unrendered effects). If it were me, I’d transcode them to QT movies first, not changing the frame size nor the frame rate. ProRes would be my choice for the codec used.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Ignatius Gorin
    December 6, 2010 at 10:03 am
    Thanks, I converted everything to PRORES HQ with MPEG Streamclip ; looks about ok.
    Thanks again for your input.
    — IG
