Activity Forums Apple Final Cut Pro Legacy Working between Final Cut 7 and Final Cut 5- how to export so it’s backwards compatible?
  • Working between Final Cut 7 and Final Cut 5- how to export so it’s backwards compatible?
    Posted by Amy Ruhl on August 18, 2011 at 4:24 pm
    Hello Everyone,
    Thank you in advance for looking at this post.
    I am working with an editor right now on a short film. She has FCP 7, and I have FCP 5. I will be actually doing the final cut of the film, based on her sequence. Is there anyway she can export her sequence so it’s compatible with my older version? OR is this solution to use an XML or EDL (which i’ve never used before and not exactly sure HOW to use)
    Any advice would be much appreciated.
    Amy
    Joseph Owens replied 15 years ago 4 Members · 3 Replies
  • Jerry Hofmann
    August 18, 2011 at 4:53 pm
    XML export from her system can be opened in yours. She exports it, sends it to you, and you import it. It will open as an offline set of files, including her sequences. Then you need to reconnect the video and audio files to it.
    It will work best if your media files are exactly like the ones she’s using… down to the frame exact.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jeremy Garchow
    August 18, 2011 at 6:13 pm
    What format is the video?
  • Joseph Owens
    August 19, 2011 at 5:56 pm
    I’d do a media manage with handles if that’s appropriate and export a master xml of that project — you’ll have to revert back a couple of versions of XML — I don’t know which would be compatible with FCP5 — maybe XMLVs4?
    jPo
    You mean “Old Ben”? Ben Kenobi?
