Activity Forums Apple Final Cut Pro Legacy Workflow? DVCProHD from FCP 6 into DVDSP4 for SD DVD
  • Workflow? DVCProHD from FCP 6 into DVDSP4 for SD DVD
    Posted by Mark Suszko on January 20, 2011 at 10:31 pm
    What’s a fast and bulletproof method to export Some DVCProHD from FCP 6.6.0 to make a standard def DVD in DVDSP4?
    I want to end up with a letterboxed SD DVD, and am wondering among many things whether to pre-shrink the DVCProHD in the FCP timeline, have Compressor handle it, or have DVDSp4 handle it.
    Michael Sacci replied 15 years, 7 months ago 2 Members · 3 Replies
  • Michael Sacci
    January 20, 2011 at 11:14 pm
    Search the DVDSP and this forum, there are hundreds of post about this.
    Export Self-contained, Current settings, into compressor DVD preset making sure you keep it at 16:9.
  • Mark Suszko
    January 20, 2011 at 11:44 pm
    *Which compressor DVD preset? For a 5-minute piece that was DVCPro HD,1080, 24p.
    It has to play correctly on cheap consumer DVD players.
  • Michael Sacci
    January 20, 2011 at 11:49 pm
    Once again this has been posted a ton of times.
    For shorts always use CBR encoding, so start with whatever you want, change encoding mode to CBR, Set average to no more than 7.5Mbps (audio also needs to be encoded as ac3 @ .192Mbps for stereo). In the frames tab, Turn on Frames Set the Resize Filter to Best.
