Activity Forums Adobe Premiere Pro workflow with wanting to sub-clip a synced up (PluralEyes) seq/clip
  • workflow with wanting to sub-clip a synced up (PluralEyes) seq/clip
    Posted by Paul Dougherty on May 5, 2015 at 12:56 am
    I’m very fond of sub clipping. If I don’t opt to create new clips (after syncing up) I’m working off a sunk up TimeLine that doesn’t led itself to sub-clipping (right?) The alternative is to create new clips that marry the video to the good audio. (that is not a one-to-one relationship with the video originals*) That creates a new set of source materials, and probably a much bigger storage footprint. Then too, you have to tell the client the original shoot materials are not enough to archive and/or reconstitute the edit. It’s not that loaded a thing but another layer of complexity and overhead… some clients might find it burdensome.
    Do I have this straight and is there a workaround, middle way I have missed?
    * I don’t have a lot of experience with PluralEyes but can one force a 1-to-1 creation of new files that match the video originals (same in/out & duration)?
    Paul
    Paul Dougherty replied 11 years ago 2 Members · 2 Replies
  • Paul Neumann
    May 5, 2015 at 4:15 am
    Merge clip. Then subclip away.
  • Paul Dougherty
    May 5, 2015 at 12:03 pm
    Sounds good Paul, thanks!
