Activity › Forums › Adobe After Effects › Workflow with Narration in AE
  • Workflow with Narration in AE
    Posted by Frank Maher on September 6, 2022 at 8:12 am
    I was hoping to get some advice on general workflow in AE that people use and also how people would best approach incorporating narrative / explainer audio into their workflow. I am making educational videos for a learning platform. I’m very much a learner of AE still and finding my way.
    1)
    In terms of workflow within AE, I am finding that a typical video is running to 5-10 mins. In terms of AE’s performance is it better to divide various ‘scenes’ within the video into separate project files and then combine them later on into the final video or does it make much difference? Is there any other approach that people might use for this approach that I haven’t thought of that would be better. AE struggles at times in previews and I wonder if the size of the project files is contributing to this and could be circumvented by smaller individual projects that I’d later combine into the final video?
    2)
    The workflow is pretty much animating around explainer audio. I don’t particularly use any video footage and pretty much everything is being generated in Illustrator / AE. Right now my approach is initially work with audio in a DAW (I’m quite comfortable working with audio) and then import that into AE and then animate around it essentially. There is a lot of pre- and post tweaking in the sense that I often have to animate loose scenes before importing the audio as I am generally developing the two in parallel as ideas come. I don’t know what people would think of this approach and any suggestions for improvements are welcome. I’m unfamiliar with but have access to other programs such as Premiere Pro but could conceivably go about learning if it would worth my while in the long run. It strikes me animating around the audio is the main thing and that needs to happen within AE but I’m new this and open to any suggestions.
    Thanks for any suggestions! Much appreciated.
    Frank
    Walter Soyka replied 4 years ago 2 Members · 1 Reply
