Activity Forums Adobe Premiere Pro Workflow tips with EX1 files, please
  • Workflow tips with EX1 files, please
    Posted by __peter__ on July 13, 2008 at 3:55 pm
    Hello 🙂
    just wanted to ask what is your preferred workflow, getting footage of the ex1 into Premiere.
    When I download the card with the clipbrowser I get a folder in which a folder contains a subfolder for each clip. That’s not very straight forward 🙂
    Do I really have to import each of them by making my way through 3 Folders ? Shurely not. There must be a better way.
    The only export posibillity seems that “mxf” format which can be imported but won’t play in realtime.
    Those MP4 files play beautifully but it cannot be that I have to import one clip at a time if a have maybe a hundred after a shooting day 🙂
    So thank you for any tip and ideas !
    Peter
    __peter__ replied 18 years, 2 months ago 2 Members · 2 Replies
  • Glenn Triggs
    July 14, 2008 at 6:07 am
    i had the exact same problem during a shoot for a feature on the ex1. finally worked it out. it’s pretty simple. go to premiere and select import – (you have to select import to do this) – then find your folder with all the files in it – not the bpav folder – the one before this – you would of names it something yourself – then hit IMPORT FOLDER – all the files will open in premiere – an error may come up – ignore it – open the folder on the left of premiere and all your mp4 files will be there – no time at all.
    good luck
    -glenn
  • __Peter__ Create COW Profile Image
    __peter__
    July 14, 2008 at 7:24 pm
    Thanks! Great 🙂
