Activity Forums Apple Final Cut Pro Legacy Workflow refinement
  • Workflow refinement
    Posted by Mark Cookman on September 1, 2009 at 4:05 pm
    During the project editing and approval process I spend a lot of time scrolling down the File>Export:QuicktimeMovie> Settings: > currentsettings …selection list.
    Over time this comprehensive list has been getting longer.
    I have tried loosing some of the unused default formats which does reduce the contents a little but I want to ask if there is any way to bring my favourite export choice to the top of the list?
    Mark Cookman replied 17 years ago 4 Members · 5 Replies
  • Dennis Leppell
    September 1, 2009 at 4:15 pm
    create a droplet in compressor of your favorite export settings and let it live on your desktop. Then, export a self-contained movie. Drop the movie onto the droplet, and compressor will do the rest.
  • Mark Cookman
    September 1, 2009 at 4:35 pm
    Thanks for the idea Dennis – it would work but I would like to reduce the amount of steps to get a file out.
    atm. that “favourite” setting is right there in FCP as standard.
    I want to avoid scrolling down that long long list x times an hour if I can help it.
  • Jason Brown
    September 1, 2009 at 7:13 pm
    I have the same thing with exporting still images. In AVID, you can customize export – JPEG at med quality…200×150…or whatever. It’s much better than “most recent settings” !!
    -Jason
  • Maurik De ridder
    September 1, 2009 at 8:54 pm
    Hi MarkCookman
    Don’t now if you’re doing this right now, but you can select the first one in the list and then type in the first letter of the one you’ll be using… It will go then to that part in the list
    I use it when I want to go to Custom (at the most bottom of the list)
    Then I type X.. which makes it go to XDCAM (not behind my computer, so it’s a bit of a guess)… this skippes 95 % of the list
    Greetings Maurik de Ridder
    Freelance Editor
    MacPro 2x 2.26 GHz Quad-Core Intel Xeon, 6.0 GB RAM, ATI Radeon HD 4870, Multibridge Pro, Sonnet Fusion DX800Raid 8TB
    QT 7.6.0 FCP 6.0.5 Color 1.0.4 Compressor 3.0.5 Episode 5.1.1
  • Mark Cookman
    September 1, 2009 at 10:14 pm
    Nice one; I never heard of that shortcut , it sound’s PERFECT …I can’t wait to try it out tomorrow.
    regards
    Mark
