Activity Forums Adobe Premiere Pro Workflow Question — Multiple Resolutions, ideal sequence settings?
  • Workflow Question — Multiple Resolutions, ideal sequence settings?
    Posted by Jesuit Lewis on April 22, 2016 at 7:06 am
    Hi there,
    Sorry for what I’m sure is a stupid question that has been asked before, but there are is A LOT of conflicting information out there and I wanted to ask the experts. I’m new to Premiere Pro CC 2015 (from FCP7), am shooting a project with footage from multiple cameras and multiple resolutions — 4K, 1080p and some ‘archive’ material from old iPhones and other lower resolutions . . . I’m just trying to understand what is happening under the hood of Premiere Pro. The delivery is most likely going to be in 1080p but I want to leave open the possibility of something higher for the future. Should I be editing in a 4K timeline and scaling the lower resolutions up to match it, and exporting whatever my deliverable is at the end? Or start working in a 1080p timeline to begin with? What happens for instance to the native 1080p that was “scaled up” in the 4K timeline then exported back to deliverable at 1080p? Is premiere pro doing fancy math at the end export to understand all of that, or is that 1080p footage being resampled/scaled twice? Or if I zoom in (or stabilize) a 4K shot in the 4K timeline losing some sharpness in the process, will that become irrelevant once exported to 1080p? What workflow has worked best for you guys? THANKS for any info!
    Jeff Pulera replied 10 years, 5 months ago 3 Members · 4 Replies
  • Alex Udell
    April 22, 2016 at 3:39 pm
    hmmmm….
    does any ftg of primary story content come at a majority resolution?
    I dont think PPro is so smart to do sort of double check conversion up and down on export like you are suggesting.
    is it possible to work at 4k, and treat/frame the non 4k material in a way that will require less scaling up (framing it someway)? In that case you could work at 4k and do a 1080 delvierable…
    just spit balling here…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Jesuit Lewis
    April 22, 2016 at 7:56 pm
    I appreciate it! To answer your question, the majority of footage (I’d say 80%) is being shot at 4K , while the rest might be a hodgepodge of 720p, 1080p and still photos. What’s trickier is some of the lower res material I would probably want to reframe which means zooming in and recropping (beyond the upscale to 4K).
    In these situations is it preferable to work at the deliverable resolution instead?
  • Alex Udell
    April 22, 2016 at 10:34 pm
    Hi….
    such a tough situation.
    But scaling down from 4k to the deliverable in your case may be the solution.
    You could look at the detail preserving upscale filter in AE to process your non 4k material
    https://helpx.adobe.com/after-effects/using/detail-preserving-upscale-effect.html
    maybe batch that material out to a 4k set….
    you’ll have to be the judge there….if future proofing is that important to you.
    Alex Udell
  • Jeff Pulera
    April 25, 2016 at 1:52 pm
    If delivering as 1080p, and using a bunch of 1080p and 720p source footage, then you do not want to edit at 4K – Premiere will “blow up” the lesser footage to 4K to match sequence setting, then when you export to 1080p, the new “4K” footage is scaled back down again, but now it is soft or pixelated.
    720p footage can look good in a 1080p sequence (if not zooming in any), and 1080p footage in a 1080p sequence can have some moderate scaling applied without apparent degradation.
    Jeff Pulera
    Safe Harbor Computers
