Workflow question
In a previous thread, recently,I asked about some syncing problems I had from a Pluraleyes export to Resolve. It was solved after converting my footage from A7s and Gopro to Prores422.
I searched about the whole transcoding approach and it seems that in many forums people are divided whether it is worth it or not. My macbook pro mid 2015 seems to be working fine with editing hd footage from the original files of the above mentioned cameras. So to transcode or not is quite debatable it seems. And then there is the big question: what should I transcode, every single clip or just the ones that I am interested in using. And would that mean I would have to go through every single clip and mark it? What if i leave something out that could still be used?.. Furthermore, I haven’t transcoded all the footage and I have already maxed out my HD and would need to make a purchase.
So, all the above made me thinking and I came up with a workflow about which I would be very interested to hear your views. It would be like this:
Original –> Prores Proxy for the editing –> edit –> after locking the edit convert to Prores422 (LT or standard or HQ) for color grade and distribution.
This way I would save money because Proxy needs less HD space and I would also delete it afterwords. In this way I would only have the Prores422 as the finished work and not several terabytes of useless footage.
Do you think it is an overkill? It is definitely easier to convert EVERYTHING in Prores but I wonder why would I want to keep full HD drives lying around filled with useless footage. I would still have the original 1st gen camera files..
