Activity › Forums › Adobe Premiere Pro › WORKFLOW PROBLEM: Creating Proxies with RedCineX Pro for Adobe PR CS6…then PR -> RedCinXPro and back???
  • WORKFLOW PROBLEM: Creating Proxies with RedCineX Pro for Adobe PR CS6…then PR -> RedCinXPro and back???
    Posted by Joe Tornatore on July 13, 2012 at 6:54 pm
    My team and I shot on a Red Epic recently and while we have Premiere CS6, we’d like to offline edit using ProRes proxies and then once we have picture lock replace all the low-res files with the full quality 5k files. Ideally we’d like to have access to and color with the full 5k files in say Davinci Resolve and then send them back to premiere to combine with audio for exporting…however we only have Davinci Resolve Lite and that won’t render 5k files. So we’re experimenting in replacing the proxies and coloring in RedCine and then sending the 5k files back to Premiere for additional coloring and combining with finished audio for exporting.
    I created a preset and exported proxy files (using this guide here: https://bit.ly/ProRes_Proxies) and now we have to get the 5k files to replace the proxies.
    I exported a FCP XML from Pr and imported that into RedCineX Pro and it can correctly replace with the 5k files, however I want to send an XML back to Pr. Whenever I import the XML in Pr the sequence (while the correct dimensions and having the same edits as the proxy sequence before it) doesn’t play. I’ve lowered the settings to 1/16 resolution but the program window is still black. There is also a red line over the entire sequence. Curiously enough though, if I double click one of the clips in the edit, it opens the 5k clip in the source monitor and I can play that fine. I can even drag that clip into the timeline and it plays fine, but I would hate to have to double click each clip in our movie, and replace every edit manually.
    I’ve tried exporting xml from red cine using File-Export Shallow-FCP XML AND File-Export Shallow-FCP XML for Pr and neither are working.
    Anyone have any idea what’s going on? Is there a better workflow for proxies that we should be using??
    Thanks!!!
    – Joe
    Morten Larsen replied 13 years, 8 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    July 16, 2012 at 3:36 am
    I recently discovered the same issue. The video is not black. Click on each clip. In the Effects control panel, click on “Motion”. For whatever reason, the clips import with a scale of 0 instead of 100. Fix this for each clip (tedious) and you should be perfectly fine after that.
    I’ve reported this to Adobe, but power in numbers so I suggest you report it as a bug as well.
    I’ve not found a work-around for it yet and it’s a weak point in coloring/conforming with Redcine-X when using Premiere.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Joe Tornatore
    July 16, 2012 at 5:36 pm
    I’ve discovered a faster way to fix this. You can double click on each clip and press the reset icon next to motion…OR and even better way…highlight all your clips in the sequence and click Clip->Remove Effects, and check only the Motion box and click ok. Everything gets reset to the default 100×100!
  • Angelo Lorenzo
    July 16, 2012 at 6:41 pm
    Nice solution! Love it.
    Angelo Lorenzo
  • Morten Larsen
    January 21, 2013 at 8:22 am
    Hi Joe Tornatore
    The exporting proxy files guide link is dead.. can you find it again and post?
