Activity Forums Adobe Premiere Pro Workflow – possibility to autoUpdate footages ?
  • Workflow – possibility to autoUpdate footages ?
    Posted by Charlie Leroy on March 16, 2015 at 9:20 pm
    Hello guys,
    In order to improve our workflow we might switch from FCP7 to Premiere.
    I was wondering If it was possible to auto Update footages.
    For now we are exporting files from AFx to a server then the editor will choose the footage and import it (for ex: footagename_v0x.mov ).
    Would it be possible to have some kind of Watch folder where for every new version of a footage will be updated automatically or by pressing a refresh button( file would be something like that : footagename_v0x+1.mov )
    is it possible natively or using a script or a plugin?
    thanks a lot.
    Alex Udell replied 11 years, 6 months ago 2 Members · 5 Replies
  • Alex Udell
    March 16, 2015 at 10:01 pm
    are you adding ftg or replacing ftg?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Charlie Leroy
    March 17, 2015 at 1:33 am
    I would replace footages already added manually.
    If scripting in premiere uses extends riot or something similar I could write a script to do so.
    But if something exist already … Why not using it 🙂
  • Alex Udell
    March 17, 2015 at 10:31 am
    Well I was thinking that any scripting for a replacement can happen at the OS level….
    as long as a copy of the file lands in the same location with the same exact name….that’s what will be used.
    so:
    AFx > a file location with original file name from AFx
    then
    an OS script copies the new file to the location PPro is reading from AS the file name PPro is using.
    Alex Udell
  • Charlie Leroy
    March 17, 2015 at 3:21 pm
    hey, thanks for your help,
    what does AS mean?
    The thing is the new version of the footage would be named with an incremented version. like name_v01 name_v02 name_v03 etc…
    so PPro would have to check if there is a new version available and update it.
    doing this in Extenscript on AE would be fairly easy but I dont know how much I can drive PPro with Extend script.
  • Alex Udell
    March 17, 2015 at 3:31 pm
    sorry…
    AS is just the word as
    wherever AE is rendering to…
    run a script at the Operating system level that just copies that file
    to a different folder where PPro would be reading the file from
    but always rename the PPro file with the same name.
    that way it will always link to whatever is current version…
    you might be able to do this with a watch folder and Adobe media encoder…
    not sure if will allow overwriting though…
    Alex Udell
