Activity › Forums › Adobe Premiere Pro › Workflow PAL equipment to NTSC DVD
  • Workflow PAL equipment to NTSC DVD
    Posted by Geoff Vane on February 15, 2012 at 10:05 am
    I want to shoot and edit with PAL gear, but I’d like to create an extra NTSC DVD too.
    A. How is that done nowadays in a pro situation, when you could rent or buy whatever you need? What is the ideal source material for dual norm output (PAL & NTSC)
    B. What can I do, using just some PAL camera’s (maybe HD, maybe SD only) and a HD edit set?
    >> Time is not an issue: if I have to render a week for the best PAL to NTSC conversion, no problem. I was thinking After Effects and pixel blending…
    >> Please do not reply from hearsay; hands-on pro experience only.
    Geoff Vane replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
