Activity Forums Adobe After Effects Workflow novice questions between Premiere Pro-After Effects
  • Workflow novice questions between Premiere Pro-After Effects
    Posted by Miguel Gomez gimenez on April 28, 2009 at 5:52 pm
    First question:
    I asume working with a huge loseless exported video from premiere in After Effects might make it almost impossible to edit without it freezing (and my computer is dual core intel and 4gigs ddr with a graphic card Nvidia GeForce 7950GT). Am I right?
    Second question:
    Are there any tips to work with loseless to optimize the editing process? Appart from lowering the resolution of the composition preview window.
    Third question:
    Also, is this the best way to do it? Edit a video with premiere, and then export it loseless, and finish it with after effects?
    Fourth question:
    Is the following possible without messing the right timing at some point?:
    1: Export an edited video to loseless with Premiere
    2: Use virtualdub to compress it to Divx (for example)
    3: Import the Divx with After Effects and apply all of the effects on top of an adjustment layer.
    4: Once finished replace the divx file behind the adjustment layer with a loseless one and export loseless again.
    5: Compress with Virtualdub
    Fifth question:
    Which is, as of today, the best compressing codec you can think of in order to release a video into youtube or vimeo? I have used Divx until now, got nice ressults with 310mb 9,5 minutes of footage and 720p at 3000kbps and 48khz audio. But does this sound right with that setup?
    Thanks beforehand, I understand these are a lot of questions 😛
    Chris Wright replied 17 years, 4 months ago 2 Members · 1 Reply
  • Chris Wright
    April 28, 2009 at 11:49 pm
    If you don’t have dynamic link, then work with low rez proxies in AE. After Effects doesn’t support Divx so it may crash.
    Youtube recommends HD video must be 1280 x 720 or higher if you want the “watch in HD” The final display size on YouTube will be 640 x 360.
    Use a bit rate over 2000Kbps for your encoded video.
    Keep your overall upload file size under 1 gigabyte and your movie duration under ten minutes.
    add the “&fmt=18” or “&fmt=22” phrases to the URL to force HD
