workflow for scanned drawings
Hi Everyone!
I am creating an animation in Final Cut from scanned drawings (all of them fine lined), and trying to figure out what would be the best work flow from Photoshop to FCP to Compressor to get the best quality video and avoid flicker.
The final outcome will be a 4:3 DVD projected 5ft x 5ft or 4ft x 4ft onto a wall using projector.1. My first question is how to prepare files in Photoshop. I currently have them saved as jpegs but I have read on this forum that TIFF is a better as it’s a less compressed format.
Also, should I resize all of the images to be 720×480 at 72dpi. I don’t need to resize them in FCP to zoom in, so not sure if 300dpi will be useful. Also, do I need to convert the images to 720×540 and then back to 480 as suggested in other places?2. What are the optimal FCP settings for such a project? I understand that I need to use ProRes422, and to run Flicker Removal filter to avoid any flicker problems. Are there any other settings I need to change.
3. As I understand, Compressor settings are standard – best quality DVD.
thanks for all your help!
