Activity Forums Apple Final Cut Pro Legacy Workflow for AVCHD 3D Files using Quicktime and Final Cut Pro.
  • Workflow for AVCHD 3D Files using Quicktime and Final Cut Pro.
    Posted by Dave Divehall on September 13, 2011 at 9:22 am
    Hello,
    I have been given some AVCHD 3D files which i need to convert to Quicktime and edit with.
    I have never worked with this before, so any help on how i can convert both Left and Right files into a quicktime and what the work flow for editing these with Final Cut Pro is would be much appreciated.
    Thanks in advance 🙂
    Katherine Sweetman replied 14 years, 8 months ago 4 Members · 4 Replies
  • Steve Eisen
    September 13, 2011 at 1:12 pm
    Before you dive into your project, you will need to learn the proper tapeless media workflow.
    Start with Shane Ross’ tutorial.
    Hint: There is a tab above.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Everest Mokaeff
    September 13, 2011 at 2:16 pm
    To work with left/right camera in FCP7 you’ll have to use either stereo3d toolbox plugin or Neo3d. Both apps are commercially available. Before you start I strongly suggest you to take your time and read as much as you can in regard of stereo film production. Otherwise you risk end up with technically-impaired movie.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Dave Divehall
    September 13, 2011 at 11:38 pm
    Great, will do.
    Thanks for the help guys.
  • Katherine Sweetman
    January 27, 2012 at 6:36 pm
    If one wanted to split the AVCHD 3D into Left Right has anyone found easy/cheap way to do this on Mac and obtain FCP compatible Left Right videos?
