Activity › Forums › Adobe Premiere Pro › Workflow for 23.976 source to 29.97 interlaced for broadcast delivery
  • Workflow for 23.976 source to 29.97 interlaced for broadcast delivery
    Posted by Stephen Pickering on September 7, 2018 at 1:23 am
    I know this question has been asked before, but I’m still not totally clear on the best method.
    I have a 1920×1080 23.976 progressive sequence using footage that is also 23.976 progressive. Because I assume progressive will be needed eventually for online use, I have everything in a 23.976 progressive timeline.
    For broadcast I need to deliver 1920×1080 29.97 interlaced.
    What’s going to be my best option for best delivery?
    1. Export the 23.976 progressive timeline directly to a 29.976 interlaced deliverable.
    2. Export a 23.976 progressive Master (DNxHD) that I then encode (via Media Encoder) to 29.97 interlaced.
    3. Since I still have the sequence, I could change the sequence to 29.976, then queue in Media Encoder where I make the change from Interlaced to Progressive. This way it wouldn’t be two exports- but would that matter?
    It seems the general consensus is option 2. Is there any advantage to do it any other way? I read about 3:2 pulldown when going from 24 to 29- Does PrPro do this automatically or do I select it (I see the option on only some of the export formats)?
    Thank you,
    Stephen
    Ricky Barrow replied 8 years ago 3 Members · 2 Replies
  • Brent Marginet
    September 7, 2018 at 3:44 am
    Don’t forget that you will not only have to deliver the show as 29.97 Interlaced but it will also likely need to be 29.97 Drop Frame. This poses a cut length issue. As an example a show that must be delivered as 45;50;00 with say 5 x 10 second blacks will need to be cut to 45:47:06 at 23.976 with 5 x 10 second blacks.
    I wish I could help you more on this but I always use Avid to do these conversions and so I’m not that familiar with how it’s done in PP.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more. Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
  • Ricky Barrow
    September 7, 2018 at 11:26 am
    I have always been advised to run the 23.976 Progressive Master through After Effects, being told it was the best method for this conversion, using the last option of the 5 listed under 3:2 (I believe WSSWW). HOWEVER, the last time I converted I found it just as good and more efficient to duplicate the sequence in PPro, change the settings and export from there.
    Ricky
