Activity Forums Avid Media Composer Workflow – Avid Xpress to Media Composer
  • Workflow – Avid Xpress to Media Composer
    Posted by Troy Miller on June 24, 2007 at 12:53 am
    I’m using Xpress Pro HD on PC. I have a short sequence (2 minutes) I want to put on Beta SP. I don’t have a deck connected to this system but have access to one connected to an Avid Media Composer on Mac. What settings and compressor should I use for quick export and import from one system to the other?
    Rhewitt replied 19 years, 3 months ago 3 Members · 4 Replies
  • Erik Pontius
    June 24, 2007 at 2:03 am
    Couldn’t you just consolidate the sequence copying the media to another drive and open the entire thing in Media Composer? The codec is cross platform.
    Erik
  • Troy Miller
    June 24, 2007 at 4:55 pm
    Because my system is PC and the other Mac I can’t connect the drive. I guess what I could do is burn the consolidated media to a DVD. I’ll try that. Thanks
  • Erik Pontius
    June 24, 2007 at 7:13 pm
    Do you have a drive that is formatted Fat32? The Mac would be able to read the drive. Avid breaks the media into 2gb chunks.
    Erik
  • Rhewitt
    June 24, 2007 at 11:50 pm
    If you need to transfer across platforms on a regular basis, I would highly recommend: MacDrive 6.
    We used this a lot before moving to an Avid LanShare environment.
