Activity Forums VEGAS Pro workflow and render of 1080 24p CineForm
  • workflow and render of 1080 24p CineForm
    Posted by Jeff Bellantine on October 24, 2008 at 12:44 am
    Here is where I am so far. I have my raw footage shot at 1080 24p which was capture using CineForm NeoHD demo. I then took the clips and edited in a HD 1080 24p time line saving the veg’s as projects. I tried 100 different ways of dragging those vegs into HD time lines and SD time lines for rendering to a format that I can run into Architect making DVD’s. It seems getting the HD veg’s into the SD time line would be the logical solution for rendering in SD but every way I have tried to render has failed (poor quality, unviewable, etc).
    Since I used the demo version of CineForm it won’t let me render into HD avi unless I buy the program, financially tough now.
    Am I doing something wrong? Should I not be nesting the vegs and then trying to render?
    I haven’t run into this before with Vegas but also never used CineForm either, I’m not even sure that is the problem. With some trials at rendering I’ve even crash my machine twice.
    Some advise and suggestion for work flow would be greatly appreciated right now, this has become very frustrating.
    Also, I am using Vegas 7e and the CineForm capture was from a Cannon shot at 24f, if that matters.
    John Rofrano replied 17 years, 10 months ago 2 Members · 1 Reply
  • John Rofrano
    October 24, 2008 at 1:45 am
    If you are targeting a DVD you can just render to DVD MPEG2 right from the HD project. I also answered your other post and suggested using the Sony YUV codec but it wasn’t clear that you are trying to render to DVD. No need to nest in an SD project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
