Activity Forums Square Box CatDV Worker Node proxy creation of spanned MXF Clips (Metaclips)
  • Worker Node proxy creation of spanned MXF Clips (Metaclips)
    Posted by Nick Shookla on May 1, 2012 at 4:00 pm
    Hello!
    I’ve noticed that when I send clips to Worker node for proxy automation, if there are any spanned MXFs (Metaclips from CatDV) in the list then it will only create a proxy for the first clip in that metaclip.
    If I create the proxies straight in CatDV via “Build Proxies”, everything is fine — it creates one proxy that resembles the entire metaclip.
    Does it sound like a setting could be wrong in Worker node somewhere? I’m just having it create H264 MOV proxy files, same thing that I create in the CatDV side (which works for spanned clips).
    Thought I would check here before entering a support ticket.. thanks in advanced!
    -Nick
    Bryson Jones replied 14 years, 4 months ago 2 Members · 1 Reply
  • Bryson Jones
    May 3, 2012 at 7:11 pm
    This should be sorted in Worker 5 (which should be out any time now.) I’m betting it’s just a bug in 4.
    Any of the Squarebox crew on this?
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
