Activity Forums Square Box CatDV Worker Movie Conversion Failures
  • Worker Movie Conversion Failures
    Posted by Will Fortune on November 29, 2011 at 3:15 pm
    Hi all,
    I’m getting errors in Worker Node with a movie conversion watch action I’ve set up. It seems that any QT or mp3 which has to buffer when I first open it in Quicktime 7, will result in a failure when Worker trys to crunch it. Since the Quicktime engine is doing the transcoding, I decided to try it manually. As I suspected, the Export function in Quicktime is grayed out until the video has fully buffered. I’m guessing this is what is causing Worker to fail. Is there a way to tell Worker to buffer movies completely before it attempts to crunch them?
    Thank you!
    Rolf Howarth replied 14 years, 9 months ago 4 Members · 3 Replies
  • Bryson Jones
    November 29, 2011 at 4:54 pm
    If quicktime is bonking, that’s a tough on. What’s the media format and what storage are they coming off of? Is it a local drive or something off of the internet?
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
  • Jon T foster
    November 30, 2011 at 8:39 pm
    Is this a non-native Quicktime file…like a WMV or some MPEG or DIVX variant that is using Perian to open in QT player?
    Jon Foster
    Sales Engineer
    Niche Video Products, Inc.
    Atlanta, GA
  • Rolf Howarth
    December 7, 2011 at 6:42 pm
    That’s interesting, I don’t think I’ve seen that before but what you describe certainly sounds possible, but something we should be able to fix if necessary. Could you send a CatDV Worker Log that shows the error to support@squarebox.co.uk so we can investigate further please?
    What kind of file are you processing? Is it a reference movie with content it has to load over the network or is it particularly long? I’m curious why it takes a while to load – just opening up an mp3 should be near instantaneous normally.
