Activity › Forums › Adobe After Effects › work with two layers as in photoshop
  • work with two layers as in photoshop
    Posted by Nathalie Wuerth on September 1, 2012 at 11:29 am
    Hej
    this is a beginners question – i was just wondering if its possible to work in two layers at a time in AE
    my impression is i either work in Composition or in Layer,
    I would like to move a set of dots (circles) according to a certain pattern and i need to be able to see that pattern when i move the dot,
    but when i am in layer i only see that layer and can not relate to the whole picture!?
    best
    Nathalie
    Nathalie Wuerth replied 14 years ago 2 Members · 2 Replies
  • Jim Arco
    September 1, 2012 at 12:06 pm
    Nathalie,
    Yes, you can work with multiple layers in AE. Although, I’m not sure I completely understand your question.
    A composition can have numerous layers. I would put the pattern in a comp, then another layer on top with the dots. Lower the opacity on the dots so you can see the pattern. Animate, then change the opacity back to 100%. If the dots move independantly, put them on separate layers.
    Jim
  • Nathalie Wuerth
    September 3, 2012 at 3:49 pm
    Hej Jim!
    This helped- I mainly had a problem with visibility and have now ticked the circle in the timeline section so that I can see several layers at one time. Thanks for your prompt reply!
    best
    Nathalie
