Activity Forums Apple Final Cut Pro Legacy work whith hd in sd sequence
  • work whith hd in sd sequence
    Posted by Rui Carvalho on June 19, 2010 at 9:56 am
    I have my footage in hd but i have to edit in a sd timeline, my question is, my hd is upper filde first then my sd sequence as to be upper fild firts right?? So far so good but when i export the movie and burn to a dvd to see in tv, it flic on tv why is that?? tanks
    PPX
    Rafael Amador replied 16 years, 3 months ago 2 Members · 1 Reply
  • Rafael Amador
    June 19, 2010 at 10:25 am
    [rui carvalho] “I have my footage in hd but i have to edit in a sd timeline, my question is, my hd is upper filde first then my sd sequence as to be upper fild firts right?”
    Right.
    MPEG-2 can be Lower or Upper.
    You need to make sure that Compressor understand the Field Order.
    In the Inspector > Video Format, check “Upper first”.
    In the “Frame Control”, set Output Fields > Same as Source.
    rafael
    http://www.nagavideo.com
