Activity Forums Adobe After Effects word transforming into antoher word
  • word transforming into antoher word
    Posted by Arno De facq on September 9, 2014 at 3:05 pm
    Hi
    I’d like to know how to create the following effect:
    https://youtu.be/0ObMMRcu0qk?t=1m20s
    The text transforms into another text, but it doesn’t just fade, it actually transforms (or it at least looks like that).
    Any idea how this was done?
    (also: the text being written, is that a particular effect also?)
    Arno De facq replied 12 years ago 2 Members · 2 Replies
  • John Cuevas
    September 10, 2014 at 11:32 am
    If you mean at 1:20(please provide a time code next time), it’s done by using a single mask to write the first words and enabling a mask path. If it was me, the next thing I would do is create another mask and write out my next word, set a keyframe, then copy that keyframe to my first mask. Then just apply Generate Stroke for the writing.
    If you have a wacom, you could even use motion sketch to create your words, copy the position keyframes then paste them into the mask properties on a new layer. I tried that with the word capture in this very rush and hurried example. But it should illustrate the technique: 7970_wordtransform.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Arno De facq
    September 10, 2014 at 7:13 pm
    I though I put a timecode, it seems I forgot, sorry about that!
    and yes, that’s the very basic that should maker it work, perfect! thanks for the file, I understand perfectly now!
    I’ll probably be able to use this trick for other tricks.
    Thanks again!
