Activity › Forums › AJA Video Systems › word clock?
  • word clock?
    Posted by Sean Davison on November 5, 2008 at 2:32 pm
    I need to connect the AES outputs on my Kona 3 into an Audio suite but noe of the audio kit wants to word sync to the aes outpus – I just get a loud hissing noise. Is there a way of getting the Kona to clock to another source or of extracting a word signal?
    Sean Davison replied 17 years, 10 months ago 2 Members · 2 Replies
  • Bob Zelin
    November 5, 2008 at 9:41 pm
    I assume you are willing to spend some money.
    The Lucid GENX192 will take an AES input, and create a sync’ed word clock signal for your system.
    The Digidesign Sync IO will lock to house black, and output a Word Clock signal for your audio system. If you don’t have a black gen, the composite video out of the Kona 3(the Y output) can go into the
    video Ref input of the sync IO, and will generate a word clock signal for your audio system.
    The Apogee Big Ben will also do this. Please state what your DAW is.
    Bob Zelin
  • Sean Davison
    November 10, 2008 at 5:48 pm
    Thanks Bob – I solved it with and old AES to Tdi converter and a Motu 2408. I now have a Logic 5.1 Setup
    I need to sort out Dolby E now…….
    http://www.twotallmen.co.uk
