Activity › Forums › Adobe Premiere Pro › ‘Woosh’ transition in Premiere
  • ‘Woosh’ transition in Premiere
    Posted by Mikkell Khan on January 2, 2009 at 5:15 am
    We’ve seen some sitcoms with it, especially when a character is speaking about a situation that occurred before. Everything in the last frame of the previous scene becomes blurred and seems to woosh out of view and what wooshes in is the scene they are speaking of.
    I’d like to know how this would be possible in premiere or at least after effects.
    Mikkell Khan replied 17 years, 8 months ago 2 Members · 2 Replies
  • Peter Berthet
    January 9, 2009 at 6:36 am
    without seeing it my guess would be a scene change with a bunch of motion blur on it
    rather than using a dissolve youd have to bring the joining section of your 2 clips into after effects and drop them into a new comp, position the outgoing clip in the centre of the comp and the incoming clip to the right, or left.. your choice
    check motion blur on both your layers and enable motion blur on the whole comp
    once youve done that you just have to keyframe in the ‘motion’ of the clips so they move at the same time to the right or left, one clip goes out of shot, and the new one comes in
    assuming you get the timing right on the keyframes the motion blur effect should handle most of the work for you, and there you go! you have your sitcom effect
    ~Peter Berthet
    Sydney, Australia
  • Mikkell Khan
    January 9, 2009 at 10:58 pm
    Thanks. Makes sense. I will test this out.
