Activity Forums Maxon Cinema 4D woodcut effect with scetch n toon
  • woodcut effect with scetch n toon
    Posted by Ronny Traufeller on July 13, 2009 at 12:51 pm
    hey everybody, i just found a thread where steve roberts explained to create a woodcut look by using setch n toon. I am not sure if this was just an idea or he had tried it once. I tried it too, but i use s&t for really simple outline jobs.
    so if its possible did some get experienced with that technique?
    or is there a preset of s&t who is able to handle that. It would be awesome if there is a way,
    sorry for my english
    link: https://forums.creativecow.net/thread/2/908927
    Ronny
    zaid-ysap.de
    Ronny Traufeller replied 17 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    July 13, 2009 at 2:53 pm
    no experience with the technique but it looks like you can get something like the second link if you add a Sketch Material (which should enable Sketch and Toon in Render/Effects).
    In the S&T material tabs:
    Main – Presets – Pen(Calligraphy)
    Stokes – Enable – checked
    In Render Settings/Sketch and Toon tabs:
    Lines – check off Contour, in the Contour settings that appear lower down set Mode to Position or Angle
    Shading – set Object to Custom Color – default is white that will give a black and white image with nothing but strokes.
    That’s only very basic quick set up there are *lots* of settings to change and you just have to play with them to see what you can do.
  • Ronny Traufeller
    July 13, 2009 at 5:17 pm
    jeah i will mess around with your hints, in the end s&t takes a lot of
    renderpower on my MBP, hope i find the right path in the next ours…
    zaid-ysap.de
