Activity Forums Apple Motion Won’t save!
  • Won’t save!
    Posted by Alex Wermeille on December 20, 2006 at 8:12 pm
    Very strange and ennoying issue… Still use Motion 2.0.1 on a G4 and 9800 pro GC… usualy all was working fine, but these last days, there’s no use to work with Motion… It will just not save, save under nor export!
    Anybody else incounter that problem?
    Ruff since I should make a job where Motion would just have done it!
    To be creative is the best way to be gratefull towards life
    Alex Wermeille replied 19 years, 9 months ago 2 Members · 3 Replies
  • Alex Wermeille
    December 21, 2006 at 1:53 am
    Well, found some emergency turnaround: exporting through Compressor does work… Yet, it is real spontaneous job, because the result is lone survivor… still absolutely no saved file by the way!
    An MacOS upgrade issue? Should really find some solution to this.
    Anybody had that one these last times?
  • Albertthao
    December 21, 2006 at 11:00 pm
    I get the same issue. Motion just won’t save or export without compressing or print. I did reinstall but still acting the same.
    My system spec:
    Macbook Pro 2.33mHz Intel Core 2 due with 3GB Ram.
  • Alex Wermeille
    December 23, 2006 at 6:34 pm
    Gosh! Sorry for you… was more hoping for someone replying: -Make this and make that and it’ll be fine.
    Well, have you installed the Intel upgrade?
    I was looking forward my next hardware upgrade AND FC studio IntelMac upgrade to have that problem definitely behind me!
    ;o/ Someone else?
    Wondered if it is was bug following the last OSX security patch… but if IntelMac have that issue too… !?!?
