Activity › Forums › VEGAS Pro › Won’t Play In Editor
  • Won’t Play In Editor
    Posted by Allison Brown on January 3, 2011 at 6:47 pm
    I am using Vegas Pro 10 to edit security footage, which is recorded in .asf format. I convert it to either WMV or MP4 before putting it in the editor.
    The footage comes from a variety of cameras, so the frame rate and resolution vary. Some are high def and some are just awful.
    The problem is that I can’t get any of the footage to play in the editor. If I click on a spot in the timeline it will show up correctly in the preview window, but it will not let me play what I am editing. When rendered it plays back fine.
    Any ideas?
    Jeremy Rasnic replied 15 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Rasnic
    January 4, 2011 at 12:37 am
    The formats are not edit friendly. Try converting them to something like Cineform or or mpeg-2 so that way if you re-render you don’t really lose quality (this is true for cineform but only partially true with mpeg-2 as it will not recompress unless you add fx or pan/crop, etc. As long as it is straight cuts it will only recompress those areas or the areas you change for that matter).
    If your final format is DVD, then mpeg-2 should be fine unless you are going to be doing a lot of revisions off that file.
    j razz
    https://www.jrazzcreations.com
