Activity › Forums › Maxon Cinema 4D › won’t extrude
  • won’t extrude
    Posted by Roger Throckmorton on July 6, 2018 at 2:11 pm
    Have an object in Cinema 4D lite, that will not extrude.
    Type differrent measurements in the Z axis under size in the coordinates pallet. The input window immediately defaults back to 0.
    Other objects in the same project have extruded fine and are editable in the Z axis.
    Total newbie even after I\’ve mastered it.
    Roger Throckmorton replied 8 years, 2 months ago 2 Members · 2 Replies
  • Jim Scott
    July 6, 2018 at 6:03 pm
    Hi Roger,
    To control the extrude along the Z axis select the Extrude object and adjust the Movement in the third window.
  • Roger Throckmorton
    July 6, 2018 at 8:18 pm
    Thank you!
    Master newbie.
