Activity Forums Apple Final Cut Pro Legacy wondering if I need to install the fcp 5.1.1 update
  • wondering if I need to install the fcp 5.1.1 update
    Posted by Todd George on August 15, 2006 at 9:39 pm
    Hello all
    running fcstudio on my PowerPC G5 single 1.8Ghz processor with 1.5 gb ram under os 10.4.7 I try to run software update on this machine and my version of fcp is 5.04
    to date software update has not informed me that the machine requires a new version of fcp
    well I have an intel Imac at work which is running fcp ver5.1.1
    so I did a little detective work online and found that there is a link to fcp5.1.1
    I did the required login and entry of my fcstudio details and was brought to the links
    I ran the 2006 pro apps updater and I got a dialog box that told me I didn’t need to install this on my machine
    I did review the tech specs for the upgrade prior to downloading and they state as follows: Minimum System Requirements
    Macintosh computer with 867MHz or faster PowerPC G4, PowerPC G5, or Intel Core Duo processor
    so my question is should I upgrade ?
    thanks in advance for any help on this matter take care
    Todd George
    Instructional Media Services
    John Carroll University
    University Heights, OH 44118
    Walter Biscardi replied 20 years ago 3 Members · 2 Replies
  • Jeff Carpenter
    August 15, 2006 at 9:50 pm
    I’m not sure what you found online but 5.1 is a $50 upgrade if you own the whole Final Cut Studio and a $100 upgrade if you just own Final Cut 5 by itself:
    https://www.apple.com/universal/crossgrade/
    As for needing to? The main reason to do so would be if you share projects with a machine running 5.1. Your 5.0 system won’t be able to open projects worked on in 5.1.
    If that’s not an issue then you don’t really NEED version 5.1 right now.
  • Walter Biscardi
    August 15, 2006 at 9:53 pm
    [todd George] “so I did a little detective work online and found that there is a link to fcp5.1.1
    I ran the 2006 pro apps updater and I got a dialog box that told me I didn’t need to install this on my machine”
    That’s correct. 5.1 is NOT a Software Update from fCP 5.0.4, it a new Universal version of FCP. You need to send in your original 5.0 discs and Apple will ship you the new Universal FCP 5.1.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
