Activity › Forums › Adobe After Effects › Wobbly edges from keylight
  • Declan Smith
    March 27, 2015 at 5:59 pm
    Have you tried adding a refine matte effect with chatter enabled and altered the smoothing ? I have had good results stabilising mattes using this. Also It may be that your keying is on the edge. I would suggest using the status of key light and alter screen gain / balance to suit to ensure you have a solid key.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
  • Jerry Wise
    March 27, 2015 at 8:17 pm
    our keys looked like this when we were using 4-2-0 cameras and recording on xd-cam. if you blow up the raw footage to 400% and examine the transition between his coat and the background you’ll probably see a mess of pixels…nothing nice and smooth.
  • Yuta Komine
    March 28, 2015 at 12:16 pm
    Thank you very much.
    Refine matte worked very well.
