Activity › Forums › Maxon Cinema 4D › Wobbling when animating a planet
  • Wobbling when animating a planet
    Posted by Rich Hoffmann on September 6, 2016 at 10:15 pm
    Hello,
    I’m a newbie to Maxon c4d. I’m animating the rotation of all the planets. Got all of them pretty good, except Saturn. It wobbles because I tilted the axis to get a better view of the rings. I can just select the y-axis, and scrub through the rotation fine, but when I try to set keyframes, the whole animation wobbles. Been playing with this for hours and can’t figure out what I’m doing wrong. Is there a way to lock the x and z-axes? Other solution?
    Thanks for the help!
    Rich
    Jim Scott replied 10 years ago 2 Members · 3 Replies
  • Jim Scott
    September 7, 2016 at 12:02 am
    Make whatever adjustments you’d like to the planet’s orientation (H,P,B) in the Freeze Transformation section, and then keyframe the rotation about the Y-axis (H) in the upper Coordinates section.
  • Rich Hoffmann
    September 7, 2016 at 2:57 pm
    Jim- You’re a lifesaver! I know that was a pretty basic fix, but sometimes that’s the difference between several lost hours and many gray hairs. I really appreciate you taking the time to reply. Best to you!
    Rich
  • Jim Scott
    September 7, 2016 at 4:02 pm
    You’re very welcome. I’m glad I was able to help.
    A “pretty basic fix” is always in the eye of the beholder. It’s only “basic” once you know it’s there, and there’s a lot inside C4D to become familiar with. Enjoy the journey.
