Activity › Forums › Maxon Cinema 4D › Wobble/Turbulence in Cinema 4d
  • David Biederbeck
    November 25, 2011 at 7:18 pm
    I think a little more information would be needed, especially for people like me who are unfamiliar with maya.
    -For objects, the vibrate tag will give a similar effect to the wiggle expression in After effects.
    -For particles, both thinking and generated from a emitter you can create a turbulence field.
    -The closest thing to creating something similar to turbulance displace that I can think of I would have to create using expresso and either sub-polygon displacement, and or some other deformer object.
    Again, please clarify what effect you are looking for.
  • Brian Jones
    November 26, 2011 at 2:01 am
    the Maya preview pic on that page looks like you could do the same thing with the Displacer Deformer (with everything in a Hypernurb for smoothness after).
  • Adam Trachtenberg
    November 26, 2011 at 4:26 pm
    You could also use a Random or Shader Effector in deformer (points) mode.
  • Oskar Westerberg
    November 28, 2011 at 10:31 am
    Hi Brian, that did the trick, it was exactly what I was looking for!
