Activity › Forums › Adobe After Effects › WMV Rendering Error
  • WMV Rendering Error
    Posted by Loudworld on January 31, 2006 at 10:05 am
    Whenever I try to render a comp as a WMV for proofing I get this error: AEGP Plugin Media IO Plugin: Unknown Error! MediaIO error; 0xc00d002e (5027 :: 12).
    I am running 6.5.0.97 on a Xeon Dually 3.2 gHz, 4 GB DDR3 RAM, nVidia Quadro FX 500/600 card on XP Pro, managing 2.5 TB of local, disc arrayed and network storage. I recently upgraded my primary HDD’s and did I full software reload on a fresh OS. I don’t think my hardware is the issue. I am also using GridIron Nucleo although it is not used for WMV renders.
    I was able to render WMV’s before my reload, but AE now returns that error on the first or second frame of the comp. I have tried my previous render template and about 100 different codec combinations.
    Adobe offers no support on this error and I have search the web exhaustively for support without success.
    I am able to render to every other format without issue. I use WMV’s to provide proofs for clients before their content goes to DVD and this problem is costing me dearly in productivity as I have to render to AVI then squish a WMV out of my AVID.
    I am at my wits end to say the least. Any insight would be greatly appreciated.
    Thankx,
    Lou
    Haldar replied 19 years, 11 months ago 2 Members · 3 Replies
  • Haldar
    November 4, 2006 at 6:31 pm
    I know this is a late response, but I’ve had this problem for some time. I found something that works for me and am trying to get this fix posted wherever I can. I found this info in a post on the Adobe forums – there is a “Secret Preferences” setting:
    1) Hold the shift key
    2) Edit/Preferences/General
    3) Release the shift key
    4) Previous
    5) Secret! Voila!
    I selected “disable Layer Cache” and set it to Purge Every 10 Frames and it not only took care of an “unspecified drawing error”, but I am now able to render wmv files with no problem.
    I wanted to let you know about this so you can tell others that have the same problem.
    -HJ
  • Loudworld
    November 5, 2006 at 3:59 am
    Bruddah! You da man, that fix cleared up my problem entirely! I had a short term fix, since I posted my problem, and that was to never use WMV’s or JPEGS in my comps. I would use other programs, PS CS2 and AVID Express Pro HD to convert my clients files to AVI’s and PNG’s then I had no problems (mostly).
    I applied your fix and it has been rock solid ever since.
    “Secret’ settings eh? Thankx Adobe, how about a ‘secret’ payment for your 1000 buck software?
    Thankx again, it wasn’t too late!
    Lou
  • Haldar
    November 6, 2006 at 3:16 am
    Sweet!!
    Glad to hear someone else is benefiting from this info as much as I am! I also emailed back the Adobe support case I’ve been working with for the last TWO WEEKS that I solved the problem & to pass along the info to others.
    Good Luck! & post this fix anywhere you can – I would have killed for this info three weeks ago when I had to tell a client I couldn’t give them a wmv to imbed in a PowerPoint………..
    -HJ
