  • Posted by Scott Spencer on January 12, 2010 at 4:53 pm
    I am trying to export my timeline from FCP using QT conversion, the windows media setting. I have flip4mac, however, when exporting it only exports 29 secs of the timeline, not the whole thing.
    I have tried numerous options in compressor and various settings in qt conversion. I can export a QT movie correctly. Furthermore I don’t want to do this in two steps.
    I simply want to know if anyone has had this problem and how they fixed specifically this problem if so.
    Scott
    Al J. marschke replied 16 years, 8 months ago 3 Members · 2 Replies
  • David Bogie
    January 12, 2010 at 5:48 pm
    Yar, it’s weird how often we see this message, You must purchase the full version of Flip4Mac to perform exports.
    If you open and read the stuff that came with the freebie, you’ll see how it works.
    bogiesan
  • Al J. marschke
    January 21, 2010 at 6:00 pm
    Same problem here. Pretty consistent. I works fine when you export at the full frame size but if you use 320×240 it will not do it.
    I have flip4mac but forgot to register the SN#. Once I did that everything worked great. You should be ok if you maintain full size without f4M.
    AL J. Marschke
    BluMars Media
    Pittsburgh, PA
