Activity Forums VEGAS Pro WMV Custom template settings
  • WMV Custom template settings
    Posted by Jerry Black on August 8, 2007 at 7:18 pm
    Need some input please.
    I have training piece that I need to render out to WMV 9 but want to take advantage of the best settings to retain as much quality as possible. Raw file is DV AVI format.
    Project settings are 320 X 240 Progressive, 29.97fps,deinterlace blend mode. I am attempting first to modifiy the default WMV tempate to first move the slider from 90% to 100%. If I attempt to make and changes to the default template, rename it, then save an attempt to apply it I get a message that the settings are not consistant with the project settings and the template has been filtered out. So I am basiccally unable to modifiy the standard WMV default. The changes I have made to the custom template were retained but I am not able to use it.
    Can someone please assist me with a solution in modifying the defaut WMV template?
    Thanks very much
    Mike Kujbida replied 19 years, 1 month ago 2 Members · 1 Reply
  • Mike Kujbida
    August 9, 2007 at 7:57 pm
    It’s my feeling that changing the properties to something other than their original media settings are why you’re running into problems.
    Since you’re starting with DV-AVI, I’d leave the project settings at NTSC DV (720×480, 29.970 fps).
    It’s when you go to render that you choose the various options such as 320×240, etc.
    I just tried what you want to do with an HDV file (project properties set to HDV 1080-60i – 1440×1080, 29.970 fps) and had no problems customizing any of the WMV templates to the settings you described.
