Activity › Forums › Adobe After Effects › Wizard of Oz Effect
  • Wizard of Oz Effect
    Posted by Phillip Chandler on September 3, 2012 at 3:50 pm
    Similar to when Dorothy leaves her house and enters the Land of Oz, I would like to create the effect of leaving a B&W world and entering a color one.
    In my shot I have a hallway that I want in B&W, and a doorway where everything beyond it will be in color.
    Currently I have my footage as one layer, and then an adjustment layer where I placed the B&W effect, and then masked and inverted the mask to make the doorway be in color. That creates the effect, but then as the camera moves through the doorway, the mask moves too.
    How can I make a mask track to the four points of the doorway?
    Angelo Lorenzo replied 14 years ago 2 Members · 1 Reply
  • Angelo Lorenzo
    September 3, 2012 at 9:21 pm
    If there isn’t anything blocking or crossing the doorway, you can track the opening of the door with Mocha (included with After Effects). The Mocha help file is a tutorial and should get you through what seems to be a relatively easy shot.
    Mocha is a planar (multi-pont plane) tracker.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
