Activity Forums Apple Final Cut Pro Legacy wit’s end–1 out of every 4 frames interlaced in 1080 24p
  • wit’s end–1 out of every 4 frames interlaced in 1080 24p
    Posted by Matthew Dorris on December 19, 2008 at 5:40 pm
    Sorry to kind of double post on this. Let me give you the background on this footage.
    Shot on an HVX200 in 1080i 24pA.
    Pulldown is removed.
    FPS is 23.98
    Compressor is DVCPro HD 1080p30 (From Item Properties)
    I am using the Timeline settings preset for DVCPRO HD 1080p 24p.
    Every fourth frame of this footage has interlaced fields. The other 3 frames are progressive. I don’t understand why this is happening. Anyone know anything about this?
    Matthew Dorris replied 17 years, 8 months ago 2 Members · 4 Replies
  • Matthew Dorris
    December 19, 2008 at 7:46 pm
    Hey–
    There is definitely something funky going on with the pulldown. There really isn’t a way to put the pulldown back in and then pull it out again is there?
  • Matthew Dorris
    December 19, 2008 at 8:42 pm
    Hi Dave,
    Thanks for taking the time to respond. It was capture off of a p2 card. It was brought into FCP via the Log and Transfer window, with “remove advanced pulldown and duplicate frames” selected. The strange part is that the pulldown was not removed, and i had to remove it via tools>>remove advanced pulldown.
    matt
  • Alan Okey
    December 20, 2008 at 1:54 am
    Sounds like maybe it wasn’t 24pA, but regular 24p. That might explain the failure of FCP to “remove advanced pulldown,” because perhaps it wasn’t advanced pulldown.
  • Matthew Dorris
    December 20, 2008 at 3:12 am
    That’s what I thought as well, but when I re-import the regular footage and look at the file info, the pulldown is 2:3:3:2, which would indicate it was shot in 24pA right?
    Also, when I bring it into a 1080i 24pA project in Premiere it imports correctly at 23.98 with no interlacing problems. What gets really interesting is that if I export the p2 footage i bring into premiere to a p2 folder, and then log and transfer that into FCP, it removes the pulldown correctly.
    There is something really strange going on and I’d like to fix it as I’ve already spent a significant amount of time editing.
