Activity › Forums › Adobe After Effects › With two compositions windows open, is there a way to hotkey preview main comp?
Posted by Ralph Moreau on September 1, 2021 at 2:38 pmSo love using two compositions, but it’s tedious to have to keep going back to main comp timeline, clicking on it, then hitting preview. Is there a way to edit other comps, but always preview from main comp?
Ralph Moreau replied 5 years ago 4 Members · 8 Replies -
Eric Santiago
September 1, 2021 at 2:52 pmNot sure about the PREVIEW part.
To keep the one panel open at all times I use the “LOCK” option on the one that I want to keep.
Now for this to work you need to UNDOCK the main COMP then select lock on the title (top left of panel).
Then open another comp and UNDOCK that.
It’s a pain but works well with Dual windows.
Best in 4K displays. -
Ralph Moreau
September 1, 2021 at 3:25 pmThank you Eric. Yes I use the lock workflow as well. But you still need to click in and out of your locked comp. 😢 I’m just looking for a way to not to have to touch anything and always preview a locked comp.
Eric Santiago
September 1, 2021 at 4:08 pmYea that’s a tough one.
The Preview panel would have to have it’s on Pref settings.
Walter Soyka
September 2, 2021 at 1:48 am -
Ralph Moreau
September 2, 2021 at 5:44 am -
Ralph Moreau
September 2, 2021 at 1:41 pmFigured it out – of coarse you need to have the latest update.
Graham Quince
September 4, 2021 at 11:19 amI worry about your spaceship analogy. Specifically what that means when After Effects crashes 🤣
