Activity Forums Field Production Wiring a standard XLR to a Sanken COS-11sPT
  • Wiring a standard XLR to a Sanken COS-11sPT
    Posted by Steve Garman on September 30, 2012 at 12:08 am
    I have a Sanken COS-11sPT which is the pigtail version of their great lavalier.
    I want to put an XLR on this so I can plug it right into my Mackie Onyx 24-4 board.
    I’ve looked on Sanken’s web site but they show every possible wireless connector schematic made but not just wiring to a standard 3 pin XLR.
    There are two tiny plastic coated black and white wires the same diameter and then a larger wire with spaghetti on it that I assume is the ground.
    Do you know how this mic should be wired to an XLR to work on my Mackie?
    I would appreciate any help. I’m a good solderer but I need to know which pins get which of these Sanken wires. I couldn’t tell from the wireless mic schematics which show jumpers and all sorts of different arrangements.
    I just couldn’t derive any sort of standard from the info there.
    Steve
    Steve Garman replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
