Activity Forums Event Videographers Wireless lav mic popping/buzzing
  • Wireless lav mic popping/buzzing
    Posted by Michael Calcagno on December 2, 2012 at 4:47 pm
    I’ve been using a Sennheiser G3 COMBO (A) EK100/SKP100/SK100/ME2 Wireless for interview audio for the past 6 months. I can definitely tell with my last few projects there’s been an annoying increase in the distinctive humming I hear occasionally. It increasing from nothing to pretty oticeable until there is a loud pop — then the hum goes away — only to just repeat this process all over again after a few minutes.
    michael
    Calcagno Media
    m@calcagnomedia.com
    https://calcagnomedia.com
    Brent Dunn replied 13 years, 8 months ago 4 Members · 3 Replies
  • David Wheeler
    December 4, 2012 at 3:51 pm
    I’ve never had a similar problem with a wireless mic. Hum from a wired mic can sometimes be an induced voltage from running mic lines parallel with power cords. I would check the receiver-to-camera connector and cord. If you have a backup cord, use it and see if you still have the problem. Make sure the camera mike input is not set on phantom power. If you still have a problem with a new cord, you may want to contact Sennheiser with the question.
    David Wheeler
    EX1R; EX3; nanoFLASH; FCP 7; 17″ MBP, MacPro Quad, Matrox MSO2,CS5
    dave@marcombiz.com
  • Mark Suszko
    December 4, 2012 at 8:29 pm
    It very well could be a damaged cord with a bad ground but it might also be a case of the camera’s automatic gain control fighting with the source. Are you recording audio with manual levels or some kind of automatic level control? Lay out a picture of the setup if you are able.
  • Brent Dunn
    December 11, 2012 at 5:01 pm
    Is this happening in multiple locations / set-ups?
    It can happen if the receiver is close to lighting source.
    Probably a bad cord. Try a new mic. Change the channel.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro
    with Final Cut Studio Adobe CS6 Production
