Activity Forums Audio Wireless Kit with line in option and headphone monitor
  • Wireless Kit with line in option and headphone monitor
    Posted by Kyle Garvey on October 17, 2011 at 9:10 pm
    Hi, I was just wondering if I purchased an Audio Technica Pro88W kit, if I’d be able to plug the transmitter into a mixing board to obtain a line-level signal as well as use a lavalier with it. I like the price range of these kits, and the fact that you can plug a set of headphones into it…very versatile. If I can’t do this, does anyone know of an affordable wireless kit where I can plug in a line as well as use headphones with the reciever?
    Kyle
    Eric Toline replied 14 years, 10 months ago 2 Members · 5 Replies
  • Eric Toline
    October 17, 2011 at 10:18 pm
    Look at the specs for the system. If they say line in is available and it uses a 3.5mm TRS connector then the line in would be on the ring. The tip is for mic level. Then you’d need a special cable for that.
    OTOH you could buy a 40-50db plug in pad/attenuator that would drop the line level feed to mic level but the pad is XLR in & out.
    You would need a cable to feed your tx that has an xlr on the input side wired unbalanced. It gets a bit more complicated if the console line out is 1/4″ then you need 1/4″ to xlr-m to pad to xlr-f to 3.5mm. BTW you should be monitoring at the recording device not at the receiver.
    Eric
  • Kyle Garvey
    October 17, 2011 at 10:56 pm
    Hi, thanks! It says trs input but it doesn’t say anything about line in. Honestly, I want to be able to use my trans/receive as a iem system. Idk how wacky this seems. Would a di box do the same thing as an attenuator?
  • Eric Toline
    October 18, 2011 at 12:04 am
    No. A DI box changes high impedence to low impedence. Has nothing to do with what you want to do. First rule of good audio: Get the right tool for the job. For IEM look for a used set of Comteks on ebay.
    Eric
  • Kyle Garvey
    October 18, 2011 at 12:48 am
    Eric,
    Idk these comteks look pricey. Is there a big difference between an iem and a wireless trans./receive kit? I’m just an amateur videographer but I also sing, but I’m a student and don’t have a lot of money
  • Eric Toline
    October 18, 2011 at 1:42 am
    Yes there is a big difference in that IEM’s have more headphone gain than a wireless system and are designed for the job. Limited budgets are always a problem. There is no guarantee that the AT unit will do what you want to your satisfaction.
    Eric
