Activity › Forums › Apple Final Cut Pro Legacy › wireframe size indicator?
  • wireframe size indicator?
    Posted by Tracy Valleau on February 25, 2008 at 8:54 pm
    Hello
    I’m cutting a HDV -sequence- into a SD sequence in order to keep the number of lines (1080) the same, and achieve a “magnification” of the image in the SD sequence. (Dropping HDV into a SD sequence cuts out the extra lines, and dragging that out with the wireframe handle therefore produces a soft image, whereas using the HDV sequence keeps the same number of lines.)
    Fine: I grab the wireframe handle and increase the size. What I’d love to see, and cannot find a way to see it, is the percentage increase I’m dragging out to. IE 150%, 200% etc.)
    With just video, that’s in the motion tab, but when resizing a sequence, the motion tab for the original sequence video remains unchanged…
    I couldn’t find how to see this in the docs, so if anyone knows how, I’d appreciate the tidbit.
    TIA
    Tracy Valleau replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
