Activity › Forums › Apple Final Cut Pro Legacy › Wireframe resizing issue…
  • Wireframe resizing issue…
    Posted by Jonny Cates on August 16, 2010 at 5:35 pm
    Hi…havent found a for sure answer to this…
    I just transferred an old TV show (taken from VHS) and re-edited the job, and have made a final H.264 ready for an upload. I made a mistake by not making the main clip slightly larger than the actual canvas, and have ended up with a rather jagged edge with a blue strip running all down the right and left side.
    It’s my fault for not noticing this during the editing process. I could have made the entire 50min clip slightly bigger (in the viewer with the wire frame) before I made in and out points. But too late now…
    Well, I know how to fix this on each individual clip – but there are many clips – and that will take a lonnnng time.
    “Is there a way I can select all the clips in the timeline – and tell FCP to resize each clip slightly bigger so’s that I get a crisp edge?” This is for upload on the internet, and not for a DVD output. So the edge needs to be sharp. It’s a 720 x 480. Thanks in advance for a possible shortcut, hopefully.
    – Jonny
    Jonny Cates
    Jonny Cates replied 16 years, 1 month ago 2 Members · 2 Replies
  • Rob Grauert
    August 16, 2010 at 7:35 pm
    yessss
    Scale up one clip. Highlight it in your timeline and copy it (Command + C)
    Highlight the rest of the clips in the timeline, Right – Click, Paste Attributes. Choose Basic Motion
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Jonny Cates
    August 16, 2010 at 8:08 pm
    Wow!
    Worked liked a charm Rob. Thanks!
    Jonny
    Jonny Cates
