Activity › Forums › Maxon Cinema 4D › Wireframe look
  • Simon Hutchinson
    May 20, 2008 at 6:41 pm
    Go to effects under your render settings, click post effect (top right) and enable the cell render effect. Have a play with it’s parameters to suit your taste!
  • Zach Gunter
    May 20, 2008 at 8:09 pm
    that is awesome. it kinda like sketch but without all the fuss.
  • Zach Gunter
    May 20, 2008 at 8:13 pm
    but it still doesn’t give me a wire frame look, just drawn outside edges.
  • Simon Hutchinson
    May 21, 2008 at 8:01 am
    To achieve this effect you need to increase the number of segments in your object and have “edges” checked in the cell render effect settings.
    For example if you create a cube, increase the number of segments in the x,y and z axis under the cubes object settings then render.
    This should give you the desired effect.
  • Randy Johnson
    May 21, 2008 at 10:55 am
    I generally use a hyper nurbs.
    /randy
