Activity Forums Adobe After Effects Expressions Wireframe Expression
  • Wireframe Expression
    Posted by Jason Mika on December 18, 2007 at 4:01 pm
    Greetings,
    I’m looking to create a triangulated wire frame from points
    distributed in 3d space using stroke or something similar.
    If anyone has any Ideas how to achieve this I would love to hear them. The one aspect that I cant seem to get my head around is
    how to only draw lines to the closest points in a radius around the originating point.
    Filip Vandueren replied 18 years, 8 months ago 2 Members · 1 Reply
  • Filip Vandueren
    December 19, 2007 at 12:49 am
    I presume the points of your polygon are represented by actual 3D Nulls ?
    You’d want to create a comp-size solid, apply a ‘beam’-filter to it, and give it these settings: length 100%, adjust color, and width to taste.
    the start and endpoints should both get this expression:
    l=thisComp.layer(“1”);
    l.toComp(l.anchorPoint)
    (in my example the nulls ware simplu called “1” to “4”)
    Now just change the name of the layer in the first line of the expression to draw a line from null 1 to null 2, change the expression of the endpoint to:
    l=thisComp.layer(“2”);
    Now add copies of the beam, make sure you enable “composite on original” in the beam effect (otherwise only the last beam gets rendered, and we want to see all of them), and change the expression to draw additional lines from 2 to 3, from 3 to 4, from 4 to 1, etc.
