Activity Forums Zaxwerks Wire Framed Text Question
  • Wire Framed Text Question
    Posted by Ed Daher on June 4, 2009 at 1:21 am
    Hello,
    I watched a tutorial on the Zaxwerks site that showed how to make a camera go through text that is wire framed. The tut was for Invigorator and I have ProAnimator. I was able to achieve the camera going through the wire frame but when I render it only shows the wire frame of each letter at a time and not all frames as the tutorial showed. How can I see all the frames? Your help would be appreciated.
    Ed
    Edward Wu replied 17 years, 3 months ago 2 Members · 3 Replies
  • Edward Wu
    June 4, 2009 at 9:14 pm
    Hi Ed,
    When going through the tutorial, be careful to not apply Hidden Line texture to the entire model. The front face of the text is created with Hidden Line while the sides are created with Wireframe. If you use Hidden Line for the entire model, you will only be able to see one character at a time because the models are not “see through”. If you model the characters with wireframe, you will be able to see through the model and see the wireframe of all the other models.
    Once you got the materials set up, the animation should look just as good as the one done in 3D Invigorator.
    Hope this helps.
    Best,
    Edward
  • Ed Daher
    June 4, 2009 at 11:21 pm
    Wow!! That did the trick. Thanks Edward for the tip and the quick reply.
  • Edward Wu
    June 6, 2009 at 12:18 am
    No problem. Glad to be of help!
