Activity Forums Adobe After Effects Windows64 and AE
  • Windows64 and AE
    Posted by Brian Lynn on September 18, 2007 at 12:26 am
    First question, will AE run on Windows 64?
    And if it does, can AE use what ever RAM you have available? I know I’m limited to the 3gb/1gb limit on 32 bit Windows if I have 4gb and the switch turned on, but I’ve not been able to find anything that directly addresses Cinema4d or After Effects on a Windows 64 machine…
    Anyone know?
    Brian
    Jan Sherlink replied 19 years ago 2 Members · 1 Reply
  • Jan Sherlink
    September 18, 2007 at 7:02 am
    AE and Cinema 4D will run on XP64 (guessing Vista64 also).
    There’s even a 64bit version of Cinema 4D but 32bit version will run too.
    In AE you’ll have access to all 4 Gigs installed (if your motherboard supports it)
    Jan
