Activity › Forums › Apple OS X › Windows XP/iMac/Airport Extreme Printing problem
  • Windows XP/iMac/Airport Extreme Printing problem
    Posted by Ron Thompson on September 6, 2006 at 10:24 pm
    Hi all, hopefully you can help. Doesn’t seem too complex, but I’m definitely missing something.
    I have a iMac CoreDuo 20″
    Windows XP and MacOSX
    Airport Extreme with HP printer connected.
    In all, I have 4 macs on the network, all print via Airport or ethernet (including iMac Intel–airport)
    When I switch to Windows and try to print, it does not see the printer, and when I go to install printer, it doesn’t see it. Windows is definetely on the network…I can surf the net, etc…
    Any ideas? Am I missing an Airport printer driver from Bootcamp?
    Ron
    Jeff Carpenter replied 20 years ago 2 Members · 4 Replies
  • Jeff Carpenter
    September 7, 2006 at 1:44 am
    Have you gone to the printer manufactuer’s web site and downloaded the Windows driver for that model?
    I’d start with that…not sure it will fix it totally, but let us know once you’ve tried that.
  • Ron Thompson
    September 7, 2006 at 1:58 pm
    oh yeah….drivers!! I’m so spoiled with the “it just works” Mac. It’s a new printer, so I have the install disk. I’ll give it a try.
    But I thought at the very least Windows would see something.
    Thanks, I’ll let you know how it goes.
  • Ron Thompson
    September 8, 2006 at 4:02 pm
    Hi Jeff,
    Thanks for gettin back to me again.
    I FINALLY solved the problem.
    I had to install Bonjour for Windows XP from the Apple site.
    I was up and running in about 5 minutes after that!
    The link is below for anyone trying to print via Airport from WindowsXP (iMac Intel)
    https://docs.info.apple.com/article.html?artnum=107998
    Ron
  • Jeff Carpenter
    September 8, 2006 at 4:55 pm
    Thanks for updating us!
    Good to know, I don’t know if I would have ever thought of that.
